Home Forums Vinyl Cutter Discussions Roland Cutters Roland SP-540V Not cutting properly
  • Roland SP-540V Not cutting properly
    Posted by Nicholas Gormley on 23 February 2011 at 15:00
    Hi all,
    My Roland SP-540v isn’t cutting correct. When i export an Sp file to cut with the cut lines around it, it shows up in versaworks and some of the cut line wont be there. It is meanly at the bottom of the letters. Anyone any ideas of what this could be??
    Nicholas
    Warren Beard replied 14 years, 10 months ago 9 Members · 12 Replies
  • 12 Replies
    23 February 2011 at 15:04
    quick guess, the eps page border is to small and clipping the cut path.
  • Neil Speirs
    23 February 2011 at 16:24
    Have you tried zooming in on the file in versaworks, sometimes I get this issue but the wee red buggers are actually there on closer inspection.
  • Nicholas Gormley
    23 February 2011 at 16:26
    I checked the page size and its OK, I have zoomed away in and they still aren’t there.
  • John Harding
    23 February 2011 at 16:27
    have you done a test cut and are those points missed ??
    23 February 2011 at 16:49
    I’m with Chris on this one cause its happened to me before 😀
  • Richard Urquhart
    23 February 2011 at 17:06
    YES its got to be EPS margin I set mine at 1.00mm
  • Nicholas Gormley
    24 February 2011 at 10:48
    Cheers everyone. My EPS margin had changed to 0mm and I changed it to 1mm. Problem solved. Thanks for the help.
  • Gert du Preez
    24 February 2011 at 13:10
    Where do you adjust the eps margin 😳
  • Nicholas Gormley
    24 February 2011 at 13:38
    Go to Edit, Queue A or B Settings (which ever you use), click file format on the left hand side and it will be at the top. Adjust to suit.
  • Chris Windebank
    24 February 2011 at 16:39
    strange, just checked mine and it is set to 0.0mm but has always cut fine. You get it sorted Nicolas?
  • Nicholas Gormley
    24 February 2011 at 16:41
    Yes all sorted now Chris. Mine was set at 0.0mm as well and when I changed it to 1.0mm it solved my problem.
  • Warren Beard
    24 February 2011 at 16:56
    I was advised by Roland to set it to 0.5mm and never had a problem.
