Home Forums Vinyl Cutter Discussions Roland Cutters Roland Soljet Pro 3 Contour Cutting
  • Roland Soljet Pro 3 Contour Cutting
    Posted by david henderson on 17 February 2009 at 09:44
    We are having problems cutting out lettering , the blade does not seem to protrude as far as it used to, yet it does not look broken, could this be a problem with the blade housing?
    david henderson replied 16 years, 10 months ago 2 Members · 3 Replies
    17 February 2009 at 09:49
    im doing this from memory but…
    the blade holder part at the end is normally a nylon type section. try turning that and it should expose more/less blade.
    may not be the answer but just a thought…
    p.s. an intro post in say hello forum would be good? 🙄
  • david henderson
    17 February 2009 at 10:03
    thanks for that Robert. You’re right about the turn and expose thingy.
    I know we need either a new blade or a new housing for the blade but they’re not cheap and I don’t want to order both?
  • david henderson
    19 February 2009 at 13:20
    I tried to say hello but couldn’t work out how to?
