Home › Forums › Vinyl Cutter Discussions › Roland Cutters › roland service call 0140 can anyone help please?
Posted by Scott.Evans on 15 January 2013 at 17:42Can anyone help please.
Roland vp 540 stops at capping station upon turning on and displays service call 0140
thanks
Scott.Evans replied 12 years, 11 months ago 3 Members · 6 Replies -
Scott
see below this comes from another site but will hopefully help you out"There is a problem with Thermistor for dryer. Thermistor cable has short circuited or cutline. Check cable connection around Thermistor or Thermistor replacement. That’s straight out of the service manual, good luck with that"
hi Kev ive just took a look do you know where the Thermistor is on the vp
thanks for the help 😀
Scott
don’t know where its located but believe its actually the supply cable this link may help youhttps://docs.google.com/viewer?url=http … P540Ve.pdf
Good call kev.
Has it got very cold in the print room it may just be struggling to get to temp.
The temp sender is under the front lower covers switch it off if going in there. . -
Hey thanks guys for the help ill check this out first thing. Over the past week it came up a few times but with a restart it would clear but now it will just not go.
Do you know how much it is to call a engineer out these days?
