Home Forums Printing Discussions General Printing Topics Roland SC545 EX – How to cut stickers with perforated parametre?
  • Roland SC545 EX – How to cut stickers with perforated parametre?
    Posted by Shaun Wakelin on 13 October 2017 at 07:58
    I have a Roland sc545ex running Versaworks and was wondering if I could cut sticker out complete
    What I mean is once it has printed onto to media and done the contour cut is there a way to get it to cut around the backing paper to make the sticker look nice and neat instead of cutting it by hand
    Shawn Bentley replied 8 years, 1 month ago 3 Members · 3 Replies
  • Martyn
    13 October 2017 at 10:18
    Yes the method your talking about is a perforated cut. i believe its down to your cutting software whether or not it allows you to use this option as well as your cutter.
  • Shaun Wakelin
    13 October 2017 at 10:47
    Can’t seem to find it in versa works
  • Shawn Bentley
    13 October 2017 at 21:08
    You will have a contour cut spot colour for your contour cutting in versaworks, you would of set this up in your cutting/design program like illustrator, basically you have to do the same for perf cut, you have to create a spot colour (any spot colour but not the one you use for contour) then you save it as PerfCut, then when you save it in a peice of artwork and bring it into versaworks it will recognise it and the perf cut will then show up in versaworks, thats basically it.
    tutorial below
    hope this helps.
