Home Forums Vinyl Cutter Discussions Roland Cutters Roland PNC 960 cutter help needed?
  • Roland PNC 960 cutter help needed?
    Posted by JoannaDingle on 21 June 2012 at 12:58
    Please be patient, I am horribly new at this.
    When cutting with the pnc960 do I have to feed the length of material to be cut prior to beginning cutting, or is there a way for it to just take what it needs?
    I am having the problem that the cutter seems to be cutting from back to front, ie cutting then going back and cutting over the line it has already done. (sucking back the material that has been fed out of the front).
    It is probably just a setting – and I have looked at the handbook, but please could someone give me an easy to understand explanation about what is happening and how to get it cutting the right way (cutting at front of vinyl then sucking from roll at back and cutting the next row and so on.)
    Thanks in advance!
    p.s. sorry about all the sucking, retrospectively it should have been feeding I guess, but hey, have a laugh on me 😀
    Brian Little replied 13 years, 6 months ago 3 Members · 6 Replies
  • Tim Painter
    21 June 2012 at 14:06
    Are you using the Roland printer driver direct? from what program?
    or a plugin?
  • JoannaDingle
    21 June 2012 at 15:49
    quote Tim Painter:
    or a plugin?
    Gosh, err….
    I think I am using the printer driver direct, I am using the cutstudio program that came with the cutter. At present I am just cutting out lots of squares and rectangles for protective covers, so nothing extravagant.
  • Brian Little
    25 June 2012 at 16:56
    Weld it
  • Brian Little
    25 June 2012 at 16:58
    Try going into plotter settings you may have it set to cut twice
  • JoannaDingle
    25 June 2012 at 17:53
    quote Brian Little:
    OK, will check. Thanks for the tip.
  • Brian Little
    25 June 2012 at 19:53
    Welcome ….just to add to that when i was using that plotter i was using signlab 4,95 but i seem to remmember if you went into the plotter settings you could look at the stack copys although it may read differnt on your software regards brian
