Home Forums Printing Discussions Roland Printers Roland PC600 Virgin ;-P
  • Roland PC600 Virgin ;-P
    Posted by m4lwu on 30 June 2005 at 10:53
    Yeah, I know…(I’m a late developer!)
    We are using it for pre-production presentations prior to volume screen printing, and went for the PC600 because we need to simulate white, silver, etc on clear vinyl.
    Driving direct from WindowsXP/Corel 12, with no general problems at all, but:
    I haven’t got a clue how to set up to use spot colours.
    Everything I do just leads to loads of beeping and flashing lights, as though I haven’t got the right ribbon loaded (but I have).
    Ideally, I’d like to lay down (e.g.) greyscale gradient tint then fill in spot colours all in one go.
    All (any) constructive advice gratefully received.
    BFN
    Malcolm
    chorley signs replied 20 years, 5 months ago 2 Members · 3 Replies
  • Mrliquid
    1 July 2005 at 00:24
    Hi Malcolm
    I have recently purchased a second hand PC-60 and am going
    through the same learning curve.
    I ended up with flashing lights also. My problem was I was that I loaded
    some silver ribbon into a Magenta cartridge and didn’t have the file to
    print a silver code sticker for the cartridge so I just set my print up
    as Magenta CMYK and it printed fine.
    Paul
  • Mrliquid
    1 July 2005 at 00:27
    ‘was I was’. Good gramma. I guess thats what you get with 2hrs sleep
    paul
  • chorley signs
    1 July 2005 at 16:18
    You may find it easier to print to the PC600 using flexi-sign- it has integrated support for spot colours and works very well with the PC60 and PC600 in my experience.
    Failing that it MAY be possible to create a swatch in Corel that is a spot colour and labelled as the colour you want the machine to output- I have little experience of Corel but it may just do the trick. Also remember that ribbons often get delivered with the incorrect barcodes on them- causing flashing lights etc
    unfortunately we don’t have ours anymore else I would try it out for you
    Hope that helps
    Rob
