Home Forums Vinyl Cutter Discussions Roland Cutters Roland pc600 colorcamm HELP!!!
  • Roland pc600 colorcamm HELP!!!
    Posted by Kelly Hartle on 29 August 2011 at 08:31
    Trying to get this setup with no software to run have no idea what to do I believe I need colorchoice ?????
    Any comments welcomed thanks
    Kel
    Kelly Hartle replied 14 years, 3 months ago 2 Members · 2 Replies
  • Alex Pirozek
    29 August 2011 at 11:37
    Kel,
    You will need a design software like Adobe Illustrator/ CorelDraw/ Flexisign/ Signlab etc etc for your designs and then to output for printing use the Roland colourchoice printer driver for the PC-600 available from Roland japan site i believe. The driver will only work up to Windows XP.
    You will also need a serial or parallel lead to link the machine to the PC or if you haven’t got a dedicated serial or parallel port on your PC then a good USB to parallel lead. I use a Belkin one with no problems, don’t go for cheap alternatives as they won’t work.
    Alex.
  • Kelly Hartle
    29 August 2011 at 12:25
    Only thing I can do from Roland is update colorchoice
