Home Forums Vinyl Cutter Discussions Roland Cutters Roland PC-60 Installation Help?
  • Roland PC-60 Installation Help?
    Posted by Adam_Randell on 22 January 2011 at 18:02
    I cant seem to install my PC-60 on anything. I am running XP in bootcamp on my mac and have another laptop with Vista on it and cant install it on either of them. I am using flexi 8.6v2
    any help would be greatly apreciated. are there any places i can take my printer and laptop to and they will install it for me?
    :police: Mod-Edit
    * Please use "Descriptive Topic Titles" when posting.
    * This posts Title has now been edited.
    Please take a moment to look over our Board Rules.
    Fabrice Menard replied 14 years, 10 months ago 8 Members · 15 Replies
  • 15 Replies
  • Ian Johnston
    22 January 2011 at 18:54
    sounds like too new programes and systems for an old machine. Windows 98/ 2000 would be more like it
    22 January 2011 at 21:43
    driver is up to XP and a real parallel port, possible on old type serial.
  • Mike Grant
    22 January 2011 at 22:50
    I could never get mine to run on XP, went back to 98.
  • Richard Urquhart
    22 January 2011 at 23:12
    Had mine running on xp pro and vista, the printer was selected from within flexisign and told which port it was connected to
    22 January 2011 at 23:15
    there used to be 2 drivers 98 then xp.
    mine still runs like clockwork ( must remember to wind it up )
  • Richard Urquhart
    22 January 2011 at 23:18
    Chris I remember years back when you helped me to set mine up, but other than missing the chrome for one job I did, god I don’t miss the pc60 one bit !
    But we do know it has its place for that one off job !
  • Adam_Randell
    23 January 2011 at 09:33
    quote Richard Urquhart:
    how did you have it connected to the Vista machine? did you have to install the drivers or are they already integrated into flexi? this is my first cutter/printer (currently a uni student trying to set up my own company) so a bit of a novice at setting machines up.
  • David Rogers
    23 January 2011 at 13:37
    If you contact your software supplier / manufacturer I’m sure they will offer
    advice via their helpline to make connecting the printer easier. After all – that’s the benefit of having top end software.
    I know companies like Cadlink offer support for their software, so think Flexi would too.
  • David-Foster-
    23 January 2011 at 14:19
    Or update relatively cheaply to a newer version that runs on Windows XP. I am sure SA International will have an upgrade policy for registered users. 😀
    Is that reply as subtle as yours Mr Rogers 😉
  • Adam_Randell
    23 January 2011 at 14:27
    its not the actual software – i have that up and running on Vista, I also have another cutter running through Flexi on the Vista machine, its the Roland drivers im having trouble with.
  • David-Foster-
    23 January 2011 at 14:30
    Just out of curiosity I searched for the upgrade prices, only found the USA ones but gives you an idea. You can upgrade from Version 8 to 10.
    Edit: Sorry just re-read that you have Flexi running, the problem is with the Roland drivers.
  • David Rogers
    23 January 2011 at 16:44
    From what I understand / read – it won’t run on Vista PROPERLY.
    XP – all the way.
    The FLEXI drivers for the Roland are IN Flexi already.
    Like I said – if you contact Flexi / Roland and they will have all of the recent patches / advice & how-to info for your setup rather than us taking a million pop-shot guesses.
  • Adam_Randell
    27 January 2011 at 20:58
    ok thanks, ill contact them both tomorrow.
    any advice on where i can get the car templates from?
  • David-Foster-
    28 January 2011 at 17:55
    I think they all use Impact for vehicle outlines on here. It’s about £130 I think.
  • Fabrice Menard
    1 February 2011 at 10:18
    I own a PC600 (not PC60), it works well under WinXP, on a PC with real parallel port and on a USB/Parallel adapter. It also worked on WinXP installed on a iMac (under "Parallels" software and MacOS 10.6.2 and a USB/parallel port adapter).
    It should work on WinVista (only if 32bit version, not with 64bit version).
    I used ColorChoice Rip.
