Home › Forums › Software Discussions › General Software Topics › roland cutter 24 inches wide
Posted by Deleted User on 14 January 2002 at 10:47hi board
i have a second hand roland cutter 24 inches wide. but i do not have software to run it.
or i should say im thinking of buying software to run it but need some advice on the best packages to use..
ive heard of signlab, flexi-sign & corel
are these the best?Alex Wilson replied 23 years, 11 months ago 3 Members · 5 Replies -
Deleted User
Deleted User14 January 2002 at 22:42I use coral draw 9, why? Because it?s cheapest I could find. lol
In its favour it isn?t very hard to use
& Has tons of other uses other than cutting vinyl. I think if I had the cash i would buy signlab. -
I suppose it depends on how much you want to spend on the software and how much work you expect to be doing. We have just purchased signlab e6 1 full(£1500) & 1 designer copy(£750 which you cannot cut from) Signlab is an excellent tool to work with. If it is within your budget i highly reccomend it.
All I care to say is if you have the money buy signlab. It’s got to be the best by far.
I’ve tried lots and none, in my opinion, come close. I think its a bit expensive but then
It is worth it in the long run. Our company have 5 fully registered signlabs
& All work flat out every day without a hitch.hmmm do you think I’ve overdone it, guys… Cadlink did give me a fiver for it after all…. 😆 😆
Deleted User
Deleted User16 January 2002 at 23:35Just thought i would mention this you guys at impact signs.
I did 4 Renault kangoo vans today & had to cut about £25 worth of vinyl again… that?s
Vinyl price to me, not customer.
The reason was & i have noticed with a good few of the vans the badges are missing on the rear doors. And the kangoo also has a large brake light at the top of the doors, bang in the centre. Again this is not on the layouts.
I know you will probably say its new models or something but these things would improve your software when doing your next disk -
I think you might find that the brake light on the back of the kangoo was’nt on the previous version disk either! I may be wrong but i think i have had that same problem a couple of years ago
