Home Forums Vinyl Cutter Discussions Roland Cutters Roland CM-300 – Issue with plotting
  • Roland CM-300 – Issue with plotting
    Posted by Stacey Clinch on 18 November 2013 at 10:53
    I am hoping that someone might be able to help.
    I’ve noticed this morning that my Roland CM-300 is having a few problems when cutting out text.
    It seem to be OK with the bigger text, or maybe that it’s just not as noticeable.
    It is as if the vinyl is slipping. the text seems disfigured.
    Has anyone had this problem with their plotter?? I’ve tried changing the blade, but that hasn’t made a difference.
    Chris Wool replied 12 years ago 3 Members · 5 Replies
  • Stacey Clinch
    21 November 2013 at 09:25
    Morning everyone……I’m still having problems with my Roland not plotting properly…..I’ve taken some photos to show what the text is like.
    Any ideas?? I know the cutting depth is too deep, but I’d just changed the blade to see if that made a difference.
    But it’s the actual cutting that seem off.
    Any suggestions??
  • Simon Worrall
    21 November 2013 at 09:51
    Stacey. I am glad you took some photos.
    Now would you care to share them so we can help with your problem? 😀 😀 😀
  • Stacey Clinch
    21 November 2013 at 11:27
    Sorry!!
    It’s been one of those mornings!!
  • Simon Worrall
    21 November 2013 at 20:16
    Stacey
    This looks like a case of incorrect blade offset.
    We had one of those on the boards a few months ago.
    It is a Fairly simple adjustment on most machines. Try different numbers until you get the one that delivers the best results for the blade you are using.
    21 November 2013 at 21:59
    If that’s small text then possibly the vinyl bunching up it must stay completely flat.
    Causes dirty or damaged cutting strip not allowing the vinyl to slide smoothly.
    Bearings in the knife holder or loose head mount.
