Home Forums Vinyl Cutter Discussions Mimaki Cutters Rockhopper won´t start printing
  • Rockhopper won´t start printing
    Posted by Marko on 14 March 2009 at 10:36
    Hi all
    Just printed few banners, all´s well. Changed the material and now it won´t start printing.
    I´m using Signlab 8 with Rockhopper printer.
    What happened?
    Barry Williams replied 16 years, 10 months ago 4 Members · 5 Replies
  • Derek Heron
    14 March 2009 at 10:40
    hi
    had a similar problem with the cadet once
    the machine has a setting for vinyl left and it thought the roll was empty
    just went through the menu and put another 100m in
    and away it went
    hope this helps
    derek
  • Marko
    14 March 2009 at 10:56
    That´s not it. It prints the nozzle check okay, but seems like it doesn´t receive commands from pc. My guess is (for now) that it has to be either port problem or cable failure.
  • Gary Birch
    14 March 2009 at 11:17
    Have you tried rebooting both. Sometimes when my Versacamm has had issues I have just rebooted both and this has worked. When switching the printer off I have to do it on the main switch and not just the control panel on/off switch.
    Gary
  • Marko
    14 March 2009 at 11:54
    Yes Gary, done that.
    Still thinking port problem…
  • Barry Williams
    15 March 2009 at 21:27
    quote Marko:
    Marko
    I often have "port" problems on my Rockhopper 38.
    Sometimes it is as a result of the IP address being lost by the Flexisign software and needs to be keyed in again in the driver setup menu (if you are using TCP/IP). On other occasions the "cannot open port" signal can be resolved by pulling the power supply out of the mini server that is under the Rockhopper (where the data cable inputs) and simply plugging it back in after a few seconds..
    Barry
