Home Forums Printing Discussions Mimaki Printers Rockhopper 3 Strange Banding
  • Rockhopper 3 Strange Banding
    Posted by Iain McCormick on 11 February 2009 at 08:19
    Hi every one,
    I have a Rockhopper 2 that I had upgraded to a Rockhopper 3 around 2 years ago to take the new Inks (eco-solvent ultra).
    We have recently noticed that we are getting banding across the face of our prints. The best way to describe it is the if you printed a soild block of colour you get 30-40mm of colour then a slightly lighter band of 10mm colour. This will repeat all the way through, and on all our media.
    I have tried all the cleaning methods our printer allows, used different profiles and changed heater settings.
    I have recently spoken to an other company who are having the same problems too, has any one else heard of this before??
    kala replied 16 years, 9 months ago 5 Members · 14 Replies
  • 14 Replies
  • Ian Johnston
    11 February 2009 at 09:09
    clean the feed rollers, if you look it will be in line with them. some materials seem to compress more with the rollers giving banding too
  • Iain McCormick
    11 February 2009 at 09:24
    The banding is running the opposite way, across the face not down the print….
  • Ian Johnston
    11 February 2009 at 09:48
    Is your machine set for automatic wiping?
  • Iain McCormick
    11 February 2009 at 09:52
    Yes, I think it’s set to wipe every 20 pass. Also I have changed the wipers, because I thought they might be contaminated.
  • Ian Johnston
    11 February 2009 at 09:54
    remove the automatic wiping, it’s not needed, that’s whats probably causing you banding.
    See if that cures your problem.
    Ian
  • Iain McCormick
    11 February 2009 at 10:39
    Will you not get ink droplets over longer prints though?
  • Ian Johnston
    11 February 2009 at 10:57
    never had much of a problem, try it to see if it cures the banding. if it does it may be as simple as changing all the wipers and setting a lower wipe rate
  • Iain McCormick
    11 February 2009 at 11:00
    Will do thanks
  • Ian Johnston
    11 February 2009 at 16:23
    HOW DID YOU GET ON?
    11 February 2009 at 16:25
    my jv3 showed some signs of lawnmower effect on solid blacks earlier in BIDIRECTIONAL, all other colours were fine so profile.
    Print in UNIDIRECTIONAL to check that everything is fine.
  • Simon.James
    11 February 2009 at 16:27
    i am thinking off buying a mutoh, well now badged uniform lancer are they a lot of rubbish cos they are awfully cheap.any comments most apprciated
    simon
  • Iain McCormick
    12 February 2009 at 09:53
    Yea it worked banding gone 😀
    Haven’t done any long prints yet, but it’s much better thanks!
  • Ian Johnston
    12 February 2009 at 14:59
    THAT’S GOOD TO HEAR 😀
  • kala
    7 April 2009 at 15:41
    i had same problem
