• Rocker cover
    Posted by Jill Broster on 6 December 2009 at 09:32
    Hi All,
    I have been asked to wrap a rocker cover on a engine along with other bits and bobs,my only worry is will the vinyl take the heat on the rocker cover,the other bits are air filter etc.Any thoughts ?
    jill
    Jill Broster replied 16 years ago 2 Members · 2 Replies
    6 December 2009 at 11:02
    most rocker – cam covers run to hot for vinyl and are normally airbrushed, if a design is required. some engine – belt covers are ok but the plastic surface don’d help.
    if you can put your hand on it and keep it there it might be ok.
    the air box temp wise is ok but fuel vapors at the edges are a problem.
    hostile area under a bonnet.
  • Jill Broster
    6 December 2009 at 12:08
    thanks for the reply Chris
    Jill
