Home › Forums › Printing Discussions › Roland Printers › Return of the mysterious ‘dropout banding’
Posted by Paul Hodges on 4 September 2007 at 14:56Some time ago, I posted about this dropout feint lines in the print on the versacamm SP540v, mostly noticeable when doing flood coated prints, we’ve had our printer nearly two years and I’ve had this intermittent problem from day one…I know others have posted about this too..
The guys at Roland have told me that quite a lot of versacamm owners are getting this fault in the printing but no one knows what causes it, therefore at the moment there is no way to stop it or work around it.
I have to say that so far, I haven’t had any work rejected because of it but I have had plenty of jobs (mostly flood coated banners) that really have been disappointing with the way the print has been inconsisitent in colour, and I’m pretty dissatisfied with this poor quality.
If anyone knows anything about this problem, please post! Otherwise it looks like this printer is rather majorly flawed in this respect.
Paul Hodges replied 18 years, 4 months ago 3 Members · 12 Replies -
its not just the roland that suffers from this, the jv3 is terrible for it.
the W-PASS profiles make life a little better. and pre-feeding the media before printing has been recommended. the frustration is that usually just as you are getting closer to a solution the problem disappears.
it does seem to appear at times of the year that are humid or warm, and then disappears for a while again. your situation may differ.
Its also difficult to pin it entirely on the printer as if this was the case then it would happen all the time and more often.
when examined with a 100x scope, the dots are all there, they are just misplaced slightly. in fact its harder to see the fault with a magnifier than just the naked eye.
sorry i cant be of more help.
quote mark optimise:its not just the roland that suffers from this, the jv3 is terrible for it.
Mark,
You’re pretty much on the money with those remarks because i have found that to be the case too, Roland also told me they get more complaints about it in the warm/humid weather, and of course, you can’t replicate the fault at will either, it’s unpredictable but i have found that it shows up in certain colours worse than others.
It just seems as though the heads don’t deliver the same consistency of ink throughout the whole flood coated job and you get very feint lines here and there.
So if it’s the case that other printers do it also, is this a common problem that we’re all just overlooking because no one knows the answer? -
does it make a difference if the media is unrolled and not pulling through off the roll?
ive had similar to what was described but found it to be media too heavy to pull through -
quote Ian Bingham:does it make a difference if the media is unrolled and not pulling through off the roll?
ive had similar to what was described but found it to be media too heavy to pull throughIan, no it’s nothing to do with the media travel, all our media is rolled off loose enough so there is no issue with the motors pulling it through off the roll, it seems purely an issue with the density or consistency of the colour or amount of ink being put down. Either that or it’s flaws in the media not allowing consistent print colour coverage but I doubt it is because it’s happened to us at one time or another on every media we’ve ever used…from vinyl to banner to canvas, even the odd paper print.
sorry to hear it, would it be possible to post a pic of the banding?
Ian -
actually i forgot to mention that i got sent some samples from a supplier last week that showed this issue and that was on a hp9000 and running from shiraz.
"It just seems as though the heads don’t deliver the same consistency of ink throughout the whole flood coated job and you get very feint lines here and there.
So if it’s the case that other printers do it also, is this a common problem that we’re all just overlooking because no one knows the answer?"when i have scoped all the samples of this fault from various rips, printers and medias, i have always seen that the dots have fired. however in the areas that show the print fault the dots are misplaced.
almost like static has pulled them of trajectory. in the cases i have seen (probably about 10) from various manufacturers of printer,media and software the dots have been firing.
i don’t think its specific to head type either, eg jv3 and Roland sharing same heads. the hp uses a fixed dot completely different head and the issues shows there as well.
i know its frustrating, Ive been on site trying to fix it!
would wiping the media with an antistatic cloth make a difference
quote Ian Bingham:would wiping the media with an antistatic cloth make a difference
maybe, haven’t tried that. the static theory may be right because i see this much more on banner media than i do on vinyl, or at least it seems to show more on banner media. i would assume banner media is more susceptible to static charge?
quote Ian Bingham:sorry to hear it, would it be possible to post a pic of the banding?
Ianprobably not completely accurate to describe this as banding, most people would think of mechanical banding and it’s not defined like that it’s more like fuzzy lines in the scan direction that are maybe 5 or 10% lighter than the colour you’re printing so they show up as feint lines, sometimes you have to look closely to see them but in darker colours they are more obvious.
it looks like media bruising however i dont think it is.
Mark, I thought that at first but I think it happens too often across the board for that to be the case.
So the dots are going down in the patchy areas, just not in the right places…I’m suspecting static charge from the roll media – particularly banner media – maybe causing this mis alignment of the dot pattern.
We may try to earth our printer and the media before it gets to the heads and see if that stops this problem once and for all
