Home Forums Sign Making Discussions Neon, LED, Lighting Replacing Neon Tubes
  • Replacing Neon Tubes
    Posted by David Hammond on 31 May 2011 at 14:15
    Had a client contact me today, they have an existing sign but a few tubes or starters need replacing.
    I am not an electrician, but can surely change a bulb/starter.
    Can I change the bulbs & starters?
    If so, would you? Or what things should I be aware of?
    Phill Fenton replied 14 years, 6 months ago 2 Members · 2 Replies
    31 May 2011 at 14:52
    Thought you use to be in the Royal Navy, come on get it right its a lamp not a bulb. Bulbs grow in the ground :lol1:
    Firstly what kind of lighting is it?? Is it Neon or is it florescent lighting they have. Big difference. If it is Neon then it is high voltage and you can’t touch it with out being qualified. If it’s a lightbox then it is probably florescent and will have tubes and starters. How long has it been there as you can sometimes try and help people out only for it to backfire on you. You can change the tubes and the starters yourself without having a 17th edition qualification but the problem comes when a few months down the road something goes wrong and they expect you to fix it for free.
    I would tell the customer that you will have a look at it and replace any existing tubes & starters that need replaced but can’t offer any sort of warranty or better still ask your local spark to look at it.
    31 May 2011 at 15:00
    Stick to sign making – tell them to get an electrician 😕
