Home Forums Sign Making Discussions Neon, LED, Lighting Replacing existing panels in panatrim framed sign
  • Replacing existing panels in panatrim framed sign
    Posted by Stuart Whitehouse on 4 May 2005 at 10:27
    I have to replace the boards on a 16ft x 4ft sign. The panels in there at the moment are 5mm foamex. Would I be alright replacing them with 3mm dibond/alucolour or can anyone suggets anything 5mm that might be better. The panels need to be yellow and I don’t want to use foamex. I wasn’t sure if there was a perspex/plastic type material thats a better quality than foam?
    also is there any other potential pit falls when doing this type of job?
    Stuart
    Martin Pearson replied 20 years, 7 months ago 3 Members · 3 Replies
  • Steve Farrugia
    8 May 2005 at 14:38
    No Anything like Dibond or alucolour is fine because it will be heavier than the foam thats in it and wont expand or contract as much.
    You will have to check the frame will take the additional weight ( they might not have fitted it properly) and you need to make sure what you use won’t be too loose and you use a correct size hanging strip cover plates etc.
  • L J.
    8 May 2005 at 15:12
    quote Signwriter:
    No Anything like Di bond or alucolour is fine and you use a correct size hanging strip cover plates etc.
    what signwriter has said is certainly correct as usual with the hanging strip being the most important as you won’t be buying 5 mm dibond. So the strip needs to be firmly glued & small self tappers into at least 8 mm strip if you are going to use 3mm / 4mm dibond
    Good luck.
    L J
    8 May 2005 at 20:48
    As LJ has said you will need a deeper hanging rail if useing 3mm sheet, plus make sure you check which type of framing it is to ensure you put the rail on the right side of the board!!
