Home Forums Software Discussions General Software Topics repeat in vinyl master pro
  • repeat in vinyl master pro
    Posted by LOST on 22 November 2003 at 13:11
    hi guys noticed a few of u guys or gals use vmp i just got it and wondered can u make a number of copies off a cut and view all copies before u cut in the
    same way as flexisgn can.
    any help much appreciated thanx.
    LOST replied 22 years ago 2 Members · 2 Replies
  • Kevin.Beck
    22 November 2003 at 15:43
    you can simply duplicate (ctrl + D) all you require cutting, then select all to be cut.
    or go to cut, then duplicate them in the cut file. move them around to get the right position, or apply the nesting feature.
    can`t remember if theres an array feature like SL.
    not 100% sure, as I don`t use VMP it all that much.
  • LOST
    23 November 2003 at 13:00
    thanx for reply becky it wasent what i was after thou i knew about them ,
    In flexisign in the cut file u just type in the amount of plots and it strings them all out for u no cutting or dublicating needed.
    thanx again mate. 😆
