Home Forums Sign Making Discussions General Sign Topics Removing vinyl from glass – advice
  • Removing vinyl from glass – advice
    Posted by Hugh Potter on 10 January 2020 at 12:32
    Hi all,
    typically when removing vinyl from glass I would just soak with soapy spray and attack it with a razor scraper, however, I’m about to do a job on around 30 large windows of frost … barely 3ft away from an indoor swimming pool, The vinyl has been on for years and looks to have slid down the glass – it’s inlikely to just peel off nicely..
    I really don’t want bits flying off in all directions and wondered if the wallpaper steamer trick is safe to use on glass?
    thanks,
    Hugh
    Simon Worrall replied 5 years, 11 months ago 7 Members · 7 Replies
  • 7 Replies
    10 January 2020 at 12:34
    Never tried it, but after watching the video below, you can soak it off.
    10 January 2020 at 12:59
    Thanks David, I’d forgotten that video, will give it a go!
    H
  • Iain Pearson
    10 January 2020 at 20:01
    The soaking merhod doesn’t always work, it depends on the strength of adhesion . Also, the video is of a 3M product.
    Personally with a spray of lubricated solution and a Triumph scraper I’d have that window stripped cleaned and refitted in half the time it takes him to get the original off
  • Chris Windebank
    11 January 2020 at 10:21
    Hi Hugh, I use a vinyl remover from Spandex to soften the film then use a triumph scraper
    https://www.youtube.com/watch?v=I4t1XugmVus
    11 January 2020 at 10:56
    Definitely don’t use a wallpaper stripper on glass unless you want to pay for new windows
  • Martyn
    11 January 2020 at 13:14
    i use a wallpaper stripper on large jobs. I had a shop last year to do, Over 30 windows 2m high by 3m long full coverage that were over 20 yrs old. I cut vertical strips about 300mm wide, heated and pulled it off at the same time being careful not to stay in one play for more than 5 secs. It worked great and removed most of the glue at the same time.
    I think you just need to be careful and use your brains.
  • Simon Worrall
    11 January 2020 at 18:54
    quote Martyn Heath:
    Use a stainless steel blade so you dont scratch the glass
