Home Forums Sign Making Discussions General Sign Topics Removing scratches from perspex???
  • Removing scratches from perspex???
    Posted by Gwaredd Steele on 18 November 2010 at 10:07
    Morning.
    Have a piece of perspex sat here awaiting some graphics. It was an existing sign that had frosted vinyl on the rear (much like Phil’s in his demo)
    Upon removing the frosted & applying orange vinyl in its place, I am now aware of loads of scratches all over the face that are now highlighted by the orange but were masked b the frosted 😕
    Any idea how to remove these? Is T-cut too harsh for perspex, as window cleaner (cream) has done nowt.
    Replacement of the panel is not an option at this stage.
    Cheers,
    G.
    Ian Johnston replied 15 years, 1 month ago 11 Members · 11 Replies
  • 11 Replies
  • Matty Goodwin
    18 November 2010 at 10:49
    Would putting the orange over the frosted be an option?
    T-Cut should be ok after all, it’s made for cars and doesn’t scratch them!
    Matt
  • Paul Munford
    18 November 2010 at 11:13
    Gwarred,
    T cut should be OK. I have used this method before to remove very light scratches from clear cast perspex sheet. My advice would be if you are not sure then experiment on a small off cut first if you have one.
  • Harry Cleary
    18 November 2010 at 11:20
    It is dealt with on one of the videos here http://www.uksignboards.com/viewtopic.p … highlight=
    18 November 2010 at 14:16
    You could try the links I posted for removing screen scratches, the products do work very well but it’s not a cheap option.
    http://www.uksignboards.com/viewtopic.php?t=49383
  • David Litster
    18 November 2010 at 14:51
    We used to use duraglit but again it only really worked with light scratches
  • Martin Kennedy
    18 November 2010 at 15:07
    We have used ‘Brasso’ for this with good success… Probably similar to T-Cut.
    Use loads of the brass to ‘scratch’ down as deep as the deepest mark, then polish with a soft cloth to make the perspex shiny again.
    Practice on a piece of acrylic first please…
    Martin
  • Tim Painter
    18 November 2010 at 15:54
    T_Cut is pretty course so add some water – or even try toothpaste.
    May sound stupid but I have used it with water in the past and removed scratches.
    Always cleans the bug sh*te off me windscreen nicely and it’s minty… :lol1:
  • Bob Clarkson
    18 November 2010 at 16:09
    G3 and water is a lot less effort than T-cut. You can actually electric mop Perspex/acrylics as you would a car or van when the paints flat/bad, just don’t push too hard or get it too hot.
  • Graeme Harrold
    18 November 2010 at 16:29
    Jewellers Rouge. I got a small tub many years ago for polishing out fine scratches in brass. CAn be mixed with brasso, water etc as its a very fine abrasive polishing compound.
    Quich search found it here
  • Gwaredd Steele
    18 November 2010 at 16:47
    Cheers for all the replies guys. I’ve had the electric buffer whizzing round on it for about 10 mins now with T-cut, & whilst some of them have gone, the rest are just too deep to get without a proper buffer wheel.
    I think it’s been used as a sledge at some point 😕
    Hopefully most of the graphics will cover them up 😉
    G.
  • Ian Johnston
    18 November 2010 at 17:59
    if the scratches are deep, then use some 1200 wet n dry sandpaper, with lots of water and sand them out, then buff up with G3, perfect.
    Ian
