Home Forums Sign Making Discussions General Sign Topics Removing emblems?
  • Removing emblems?
    Posted by Jill Marie Welsh on 27 June 2009 at 11:38
    I have to letter a truck cap this morning.
    On the back glass, which is tinted black, is a domed emblem decal.
    I have been trying to get it off using a razor blade at the edges and then dental floss, but it is not cooperating.
    I am reluctant to get out the hair dryer to heat this for fear of cracking the glass.
    It is only a small emblem, about 1½" x 4", but it is in the way.
    It’s still chilly out, maybe the morning sun (if it ever comes out) will soften it up.
    Any suggestions?
    Thanks!
    Hugh Potter replied 16 years, 6 months ago 3 Members · 5 Replies
  • John Childs
    27 June 2009 at 19:47
    I don’t know what to say for best Jilly, but I’d use heat.
    Applied very slowly, and over the whole area of the glass to minimise local expansion problems.
    I can’t guarantee the method but, if all else had failed, that’s what I’d do.
    27 June 2009 at 20:05
    That’s what I ended up doing.
    I used a hair dryer and I was real careful.
    I loosened the edges enough that I could grasp it with my thumb and fingers then I peeled it off in sections.
    28 June 2009 at 08:48
    HI Jill,
    for future reference this may help.
    if you know someone who does a fair bit of fishing, ask them if they use ‘braided lines’ and if they do, see if you can pinch a few feet,
    i use a 40lb braking strain braid on one of my reels and decided to try it when removing the badges on my toyota mpv, it works a treat, virtually unbreakable (if you keep it away from sharp edges when inder tension) and it glides through the felt pad stuff in a see-saw motion with ease. that was my experience anyways.
    also, if you get some, wrap the ends around something solid for quite a few turns, if you try wrapping it round your fingers it’ll make them a bid messy 🙂
  • John Childs
    28 June 2009 at 17:05
    quote Hugh Potter:
    HI Jill,
    Tried the fishing line trick on the GoldWing badges on the back of my bike.
    Took the lacquer off and ended up getting it re-sprayed. 🙁
    29 June 2009 at 05:56
    hmmm, i would guess it was a monofilament line (plasticy), braid is soft like string so shouldn’t do that, I wouldn’t have thought anyways!
