Home Forums Software Discussions General Software Topics Removing Background
  • Removing Background
    Posted by Dave Bruce on 27 November 2007 at 20:14
    Is it possible to remove the background of a PDF file?
    I have managed to double click it in Signlab 7.1, select the path and delete it upon which Signlab crashes 🙁 I have Photoshop (hardly use)/Coral 12)
    Anyhelp would be appreciated.
    Dave Bruce replied 18 years ago 8 Members · 10 Replies
  • 10 Replies
  • David Rogers
    27 November 2007 at 20:30
    If you post up the pdf – I’m sure somebody could do it.
  • Nick Minall
    27 November 2007 at 20:46
    Is it vectors or a bitmap?
  • Dave Bruce
    27 November 2007 at 22:38
    its a bitmap from a word document, I am not at the work computer so will do it tomorrow.
    Guys
  • tived
    28 November 2007 at 21:24
    yes, post it
    photoshop has some plug-ins like Fluid Mask and KnockOut which can do a reasonable job, depending on the difficulties.
    but I really would need to see it
    thanks
    Henrik
  • Steve Underhill
    28 November 2007 at 22:59
    Isnt knockout a Corel program?
    And fluid mask is an additional plug in you have to buy
    Photoshop uses the extract filter to create a mask round the object which is pretty good, just the standard quick mask tool is goo d enough for any task you will use in day to day usage.
    28 November 2007 at 23:06
    Untill the image is seen, hard to suggest the best method to erase the background.
  • Steve Underhill
    28 November 2007 at 23:13
    Well if youre going to use photoshop, theres only 2 methods worth using unless its so simple you can use the magic eraser function.
    either quick mask, from the tool menu or extract in filter options
    But I agree lets see the image so we can see the best way to do it.
    29 November 2007 at 00:52
    If you own Acrobat Pro then you can use editing tools to remove offending items (unless the whole thing is a bitmap)
  • Ian Higgins
    29 November 2007 at 01:33
    You could use the clipping tool in Signlab
  • Dave Bruce
    29 November 2007 at 09:52
    File now attached under graphic design help
    DAve
