Home Forums Sign Making Discussions General Sign Topics Removing adhesive from dibond?
  • Removing adhesive from dibond?
    Posted by LeeMorris on 10 December 2007 at 18:41
    Hi All
    I’ve been working on a dibond panel sign and its been a git from start to finish.
    The other day i ran out of masking tape so i used some sellotape to old some letters in place. What a mistake that was.
    What can i use to get the sticky stuff of the panel? i have tried a bit of meths and water but it looks like its going to mark the panel.
    Lee
    Gavin MacMillan replied 18 years ago 11 Members · 12 Replies
  • 12 Replies
  • Ian Bingham
    10 December 2007 at 19:02
    petrol?
  • David Rogers
    10 December 2007 at 19:03
    ‘Stick stuff remover’ / ‘tar remover’
    …or petrol.
    10 December 2007 at 19:05
    White spirit or turps would probably be better to start with, less chance of marking the surface
  • LeeMorris
    10 December 2007 at 19:12
    Thanks everyone i will give them a go
    Lee
    10 December 2007 at 19:14
    Lee try whatever on the back off the cellotape first to see if it softens the glue. then try a bit on the reverse side of the dibond for any reaction.
    Better safe than sorry
  • Phil Halling
    10 December 2007 at 19:22
    If it’s factory finish dibond then brake cleaner should do it – BUT USE SPARINGLY and carefully.
    10 December 2007 at 19:34
    Buy some Rapid Remover from Rapid Tac.
    Better safe than sorry.
    It is very gentle to substrates.
    You could also try putting a piece of good 3M masking tape over the adhesive marks and burnishing with a squeegee, that may take it off too.
    10 December 2007 at 19:39
    without having to invest in anything i think the white spirits left for ten minutes to soak on it will do the job fine. its not the best/fastest but will work. once its off clean down with meths.
  • Peter Shaw
    10 December 2007 at 19:42
    3M Industrial Cleaner is my first choice for any job like this. No solvents, just lemon & lime. Lifts glues and grease like a dream.
  • Steve Underhill
    10 December 2007 at 19:55
    Nitric acid and a belt sander always works for me. 😮
    Failing that, put some sellotape on an offcut, leave it a while and replicate the problem, then you can find out what works best for your particular problem by trying them all and have a reference for the future.
  • Neil Churchman
    Any of you guys use the Servisol label remover available in Maplins or the Maplin own brand of the same stuff.
    It’s a handy service aid product that’s makes removing vinyl glue residue
    from sign panels quick and easy.
    OK it’s not as cheap as white spirit, but if your using it in a customers office
    the lemon smell is more acceptable and no worries about spillage on the carpet
  • Gavin MacMillan
    11 December 2007 at 13:24
    My old boss always called cellotape ‘the devils adhesive’ This is something he was actually right about!
