Home Forums Printing Discussions Roland Printers Removed "Tabs" for emergency prpinting
  • Removed "Tabs" for emergency prpinting
    Posted by Lee Attewell on 19 November 2012 at 03:29
    Hiya,
    I’d heard about this but have never done it before. On Friday afternoon I had a low ink warning from versaworks for Magenta. Ok I thought I’ve got a spare cartridge. I changed out the magenta once it ran out and then five minutes later horror struck. The other Magenta ran out as well. I’d been printing 20 large prints for some glass signage I’m going.
    So I’m on the last of 20 large prints, on a Friday afternoon with no chance of getting a replacement Magenta.
    So What I did was to cut off the little plastic tab that pokes out of the side of the cartridge. I’d heard that you get a LOT more ink available if you did that but you ran the risk of totally going dry.
    I kept a close eye on it as I finished printing the 1340mm x 3600mm print which was basically solid red coverage.
    That’s right, I managed to get the whole print finished.
    Well chuffed 🙂
    Vic Adair replied 11 years, 8 months ago 10 Members · 21 Replies
  • 21 Replies
  • John Harding
    19 November 2012 at 08:53
    Thats a good tip to get you out of a hole Lee, i should cut a spent cart open to see how much is left inside 😕
  • George Elsmore
    19 November 2012 at 10:30
    have you a photo of which tab to cut?
  • John Harding
    19 November 2012 at 10:44
    George I guess its the large tab near the bottom on the side with no label
  • George Elsmore
    19 November 2012 at 10:58
    got ya 😀
  • Martin Cole
    19 November 2012 at 11:47
    quote George Elsmore:
    Not 100%, but i think it’s this one G….. 😉
    NICE TIP, btw Lee :thumbsup:
  • George Elsmore
    19 November 2012 at 12:15
    very good 😀
  • Martin Cole
    19 November 2012 at 12:55
    best I could do for a Monday morning George 🙁
    19 November 2012 at 13:45
    I don’t have a printer so this issue does not directly affect me but if it did I would feel a bit aggreived that the ink I had bought was not available for me to use. Somebody less generous than me may suggest that manufacturers are taking the pi$$ out of their customers yet again. Maybe the cartridges should be labelled with the amount of ink that is available to use rather than the ink they contain.
    Alan D
  • Martin Cole
    14 January 2013 at 20:53
    Well this evening I had one final print to do and half way through the good ol Magenta ran out.
    I cancelled the print and called it a day as I had no spare. Sitting having a cuppa and remembered this thread so I went back, removed the cartridge cut the tab off gave it a shake and wamo, it printed the whole 2000 x 900 print about 50per cent coverage.
    It’s shocking that there is still usable ink in the cartridge and the chip is telling us its empty 👿
    But over the moon as can laminate and get signs out for tomorrow now.
  • Lee Attewell
    14 January 2013 at 21:21
    Good result Martin 😀
  • Stafford Cox
    14 January 2013 at 21:59
    That’s a handy little tip that makes perfect sense. Thanks for sharing 😉
    14 January 2013 at 23:40
    there is a command in the roland menu that allows the print to continue when the cart says empty. and not stop mid print, it will continue for around 1-2 mts. or the end of that print and will not start another until the cart is changed.
    even if there is no ink apparently but never got that far yet.
    that would have saved martins first print.
    i think its fair to say that the bit of ink lost in each cart is probably better than air in the main pipes
  • George Elsmore
    15 January 2013 at 08:10
    where?
  • Martin Cole
    15 January 2013 at 08:53
    quote Chris Wool:
    As G Says ‘Where Chris’ This shouldn’t be something you have to stumble across or hear about, if its available it should be set as a default.
    valid point about air in the system -so only to be used as I guess a ‘get out of jail card’ or as Lee says emergencies..but helped me out big time last night
    15 January 2013 at 21:27
    My little tease
    Ink control
    Empty – stop
    Change to continue
    On your own head be it
    Note if a cart says empty it will not print as before
    If you start print ing andcthe cart comes up as empty it will beep and continue to print for around one square Mt even if the ink runs dry.
    It always has finished a print for me with no problems furthest so far around two mts not full coverage.
    If it finishes the print it will not print the reg marks at the end if you’re despite now cut the tag.
    It will not start another print until the cart is changed.
    Mine has been set like this for about 6 year’s and no horror stories.
    Manufacturers really have vto set the machine to help safe guard its self
    And all in the user manual
  • Martin Cole
    16 January 2013 at 17:03
    Interesting Chris Thank you.
    I’m going to get George to try it for six months and if he doesn’t F**** his printer up, I may give it a go 😀
    Nope, I’m going to set mine as you have yours Chris, I cant bear where it runs out of ink mid way through a solid colour – you replace the cartridge and you get a slight banding 👿
    16 January 2013 at 17:10
    quote :
    thats exactly what it is for but a bit of thought required thats why its not the default
  • Martin Cole
    16 January 2013 at 17:18
    quote Chris Wool:
    quote :
    I get where your coming from…thanks Chris
    6 February 2013 at 14:27
    This has just saved my skin…
    1500x1500mm PVC banner needed printing, SOLID red! Got about 300mm in and the magenta ran out.
    Shaved down the tab and it’s back printing.
    Just finished printing it now! Awesome tip!
  • Paul Atherton
    29 March 2014 at 16:27
    this would of saved my bacon so many times!
  • Vic Adair
    29 March 2014 at 21:30
    On the Mimaki cartridges there is a little tab that pops out at the back when the cartridge starts to become empty and this stops the machine from printing but if you block it and stop it coming out fully then you can get a few more metres out of the print depending how much of that colour your using but like chris says it can damage the machine if the ink pipes dry out.
    The other one is where the chip date runs out but you still have lots of ink left, that can be a pain. The fix for that is to turn the clock back on the machine so as to fool the chip into thinking it still has a few months left…..dont ask how you do it as i forgot.
    The last time i did this i managed to get the cartridge working again but putting the clock forward again was not easy. 😳
