Home Forums Sign Making Discussions General Sign Topics Remove Glue Residue – on Rollers and Cutting Mat
  • Remove Glue Residue – on Rollers and Cutting Mat
    Posted by Jack ODonoghue on 11 July 2020 at 21:05
    Help Required Please – remove Glue Residue from rollers and cutting mat – from self adhesive
    I have glue residue from a self adhesive film that is stuck on our flat bed roller laminator cutting table and also on the rollers
    Any suggestions for easily removing the glue residue from the rubber cutting mat base of the roller laminator and also residue on the rollers
    Thanks in advance for any help
    Jack
    Jack ODonoghue replied 5 years, 5 months ago 2 Members · 4 Replies
    11 July 2020 at 23:22
    If it’s ground in adhesive, I would dab on plenty of Tar & Glue remover.
    let its sit 5 minutes, dab it again soaking it and then scrape off in a dragging motion using a bare Stanley blade or old squeegee. once the gunk has come away, wipe it down with a fresh rag and tar and glue. then complete wiping it down with isopropanol alcohol.
    You can buy tar and glue remover from most places, even Halfords.
  • Jack ODonoghue
    12 July 2020 at 07:51
    Hi Robert
    Thanks for the reply, much appreciated
    It looks like adhesive from old self adhesive vinyl they were making some internal signs for the warehouse from
    Looks like one of the workers rolled the vinyl onto the cutting mat base, instead of onto a board
    Not that anyone will admit to it !
    It still feels tacky
    Would tat remover be best for that ?’
    With it still feeling tacky to touch
    Any other suggestions appreciated
    Thanks a lot
    Jack
    12 July 2020 at 17:38
    Hi Jack
    Yes, it will work for that and once cleaned properly, it will not be tacky.
    There is a process of cleaning glue, same with vans etc.
    You use the adhesive remover to break down the glue, remove it, repeat.
    once happy the majority has been removed, then clean with isopropanol which will clean any residue of the T&G cleaner away, till your left with a spotless surface.
    there is plenty of adhesive removers on the market. some better than others.
    some are weak and smell bad. others smell great but hopeless or diluted. I find the tar&glue one has great strength and low odour. just be sure to keep away from your eyes.
  • Jack ODonoghue
    12 July 2020 at 20:37
    Hi Rob
    Thanks for your words of wisdom
    I’ll order some T&G tomorrow and give the job to the guy I suspect of making the mess !
    Thanks again
    Kind regards
    Jack
