Home Forums Sign Making Discussions General Sign Topics REMOVABLE VEHICLE SIGNS
  • REMOVABLE VEHICLE SIGNS
    Posted by Dan Finn on 6 September 2007 at 14:22
    Got a customer who has bought a Landrover defender, with no windows in the rear. He wants to use the panel where the windows would be to take two alternating sets of demountable signs, needless to say the panels are not steel so can’t use magnetic. Any suggestions which don’t involve fixing through the vehicle panel?
    Ian Bingham replied 18 years, 3 months ago 8 Members · 10 Replies
  • 10 Replies
    6 September 2007 at 14:25
    dibond it pretty light, you cuold make the panels from this, and have a few long strips of velcro to hold it on.
  • Warren Beard
    Hi Dan
    Good question.
    Off the top of my head would a magnet inside to hold the magnet outside not work?
    Just a thought, not sure if the magnets will be strong enough 😕
    Warren
  • Chris Lambe
    6 September 2007 at 14:58
    My 2 pence i would use use a light wait foam board drill 4 holes and get those window sucker fixings might be an option (?)
  • Fred McLean
    6 September 2007 at 15:29
    Use d/sided tape and reverse stick mag sheet onto windows,then supply magnetic signs same shape.
    Interchangeable 😉 😀
    Have done it for a Del Boy reliant works a treat 😛
  • Dan Finn
    6 September 2007 at 16:04
    Thanks for the suggestions everyone, have tried the magnet inside and out trick but it is just not strong enough. Though of drilling through and fixing with wing nuts or suckers but want to avoid perforating the vehicle if at all possible.
    Fred’s suggestion sounds well worth a try though.
  • Chris Lambe
    6 September 2007 at 16:24
    quote Dan Finn:
    I meant drill the foam board to fix the suckers to the board 😛
    6 September 2007 at 19:06
    i’m not sure i would trust suckers to hold a sign on, it would rely on the paintwork being 100% smooth, and no dirt being there when you stick em on / change them. another potential prob would be the size of the gap behind the panels, alot of air could get under there and rip em off.
    velcro is very strong, especially when supporting the weight vertically, 3-4 strips across the width of the sign, would be more than enough to hold it, and securely too.
  • Lee Ballard
    6 September 2007 at 19:14
    Had an enquiry about a similar thing a couple of months ago, best way to do it we reckoned was use a banner and lots of velcro, especially on the forward edge.
    6 September 2007 at 19:36
    thanks fred must remember that one
  • Ian Bingham
    6 September 2007 at 19:47
    Magnets do work if you get them strong enough, try the magnets from old loud speakers, the same as taxi roof signs
