Home Forums Sign Making Discussions Vehicle Wrapping regular vinyl or vehicle wrap??
  • regular vinyl or vehicle wrap??
    Posted by Soyeb Ravat on 11 June 2009 at 13:56
    what would be better to use on a Citroen nemo??
    i would like to do the side panels which are no bigger then a meter squared of basic signs and directly applied and the back. The back again just covers the doors.
    Is it a: better to use : vehicle wrap vinyl
    or b: your regular 3-4 year vinyl
    thanks!!!
    John Childs replied 16 years, 6 months ago 3 Members · 3 Replies
    11 June 2009 at 22:52
    not exactly sure what you mean by basic signs etc but if there is panel work and the like then don’t use a 3-4 year vinyl. use a cast 8 year+ or direct to a wrap. if its a solid colour wrap try KPMF or MacTac.
    11 June 2009 at 23:07
    Not sure if I understand the question fully either sorry 😳
    Is it just a flat panel you are looking to apply vinyl to or is it a curved surface or recessed ??
    If its flat panel work then a calendered vinyl will be OK but if it needs to conform to a particular shape or there are recesses then you will need either a cast vinyl or a vehicle wrap vinyl.
  • John Childs
    12 June 2009 at 00:04
    Not 3-4 year vinyl on a van. Ever.
    5-7 minimum, even on flat panels.
