Home Forums Sign Making Discussions Vinyl reflective vinyl removal tips please?
  • reflective vinyl removal tips please?
    Posted by Richard Urquhart on 17 May 2006 at 20:37
    hi all i do many vans for one customer who uses a large amount of reflective
    now i know the best soloution to this would be to apply normal vinyl first how ever this has not been done so im looking for tips to remove this please
    thanks rich
    MartinDenton replied 19 years, 6 months ago 8 Members · 14 Replies
  • 14 Replies
  • Andy Gorman
    17 May 2006 at 20:50
    As much heat as the paint can bear, and a hard plastic squeegee. Sometimes you can tease the vinyl off whilst gently easing it with a window scraper. Different brands behave differently. Avery, for example is a bloody nightmare. Expect some paint damage.
  • Richard Urquhart
    17 May 2006 at 21:11
    andy thanks mate
    has any one used GRAFIGEL
    Why waste time? When it comes to removal try Grafigel. Fast and effortless, simply apply by brush saving hours of preparation time in removing calendered and cast self adhesive vinyls.
    but will it work on reflective
    17 May 2006 at 22:33
    Rich, it does work, it removes the vinyl, unfortunatley it leaves all the adhesive behind, so now you have use glue remover as well. but not just on a bit off remnant glue, but the whole area where the vinyl was. Dont think it works on reflective though. Try a toffee wheel, or jagsigns sell a rotary tool to do the job, expensive, but may do the job for you.
  • John Simpson
    17 May 2006 at 22:53
    Thinners fetches the adhesive off along with a cheap plastic squeggee.
    Just make sure paintwork is sound 1st.
    L J
    17 May 2006 at 22:57
    Thinners work,
    but be very, very carefull, I would not reccomend them. wrong thinners on certain types of paint = paint stripper.
  • Kev Dunn
    18 May 2006 at 10:02
    quote Peter Normington:
    Thinners work,
    Exactly!!
    My Father runs a Spray Painting business and has warned me off thinners.
    He allows me to mix a bit with Panel Wipe.
  • Richard Urquhart
    18 May 2006 at 11:27
    thinners is fine on factory paint but even on 2 pack rework its not recommended
    or acrylic
  • John Simpson
    18 May 2006 at 16:35
    obviously we try a bit of thinners on a hidden area of the "factory paint" first. we have just last week had to strip all the reflective stripes off a VW Transporter, all the way around the bottom half & replace with regulation striping. It was nearly impossible to shift all the adhesive so as a last resort tried the thinners that is supplied for thinning screen printers ink.
    It worked a treat, no problem at all, messy but quick.
    L J
  • Richard Urquhart
    18 May 2006 at 19:50
    hi mate its when its had a local that we didnt see till the thinners makes that sticky mess you know when you look on the cloth and pray you wont see the colour of the vehicle on it !!!
    oh what fun 😀 😀
  • Stephen Morriss
    19 May 2006 at 09:32
    I just had to stip a whole sign that was reflective, the best way was a window scrapper (type with a stanley blade), just be carefull not to dig into the paint and get one that has a really shallow angle Harris do a good one.
    I also found a hobb scrapper once (never seen one since but it’s got Schott on it) and it has a very thin blade in that bends, it’s really good for removing vinyl from paint work, you just have to go over it with glue remover.
    Edit
    Just found it on the web here
    wow that’s a long address :lol1:
    mod edit – edited the web addy to make it smaller 😉
    19 May 2006 at 09:49
    Rich, i use a retractable razor blade type thang, available from most vinyl suppliers i would imagine, relatively cheap at only a few quid, excellent on glass, and good on car paint, the blade is useful for either lifting an edge to get you started, or it seems to get tween adhesive and vinyl, leaving just the adhesive to remove,
    cast is another matter though !
  • Kev Dunn
    19 May 2006 at 10:32
    I have been using a scraper from Snap-On (tools), They work very well and can get a constant supply of blades.
  • John Simpson
    19 May 2006 at 16:43
    thanks for the link Steve.
    L J
  • MartinDenton
    20 May 2006 at 13:05
    we use a product called multisolve for getting the adhesive off, wipe it on, leave for a couple of minutes and it converts the adhesive to a goo which is easily removed with rags a a scraper blade company called Astral Chemical Solutions (manchester) 0800 975 6677 make it, it pongs but really works! its designed for removing tar and manufactures silicone / wax from cars
    scrapper wise I use the thin retractable one you can pick these up on market stools for about a quid each including a set of blades, the blades being thin will bend
