Home Forums Software Discussions Signlab Software Reducing nodes in Signlab
  • Reducing nodes in Signlab
    Posted by M Brown on 8 June 2010 at 08:46
    Hi All,
    I have a logo that I’ve scanned in to SignLab and after I vectorized it it has loads of nodes. I seen somewhere once that you can remove some of the nodes by selecting some and SignLab would smooth them out. I cant remember how to so it.
    Can someone shed some light on where to find this function on Signlab 8.
    Many Thanks
    From Mark
    M Brown replied 15 years, 5 months ago 3 Members · 4 Replies
    8 June 2010 at 08:53
    Select nodes,
    press u – this deselects every other node
    Press r to delete nodes that are selected.
    Reduces nodes but is a bit of a ‘dirty’ solution as it is indiscriminate how it works ie the node deleted maybe a corner or important curve node so shape can change. Compared to Corel’s reduce nodes it needs some work.
    Alan D
  • Paul Munford
    8 June 2010 at 08:56
    Try this,…..
    Double click the object…then sweep select all the nodes…type "u"… then hit delete. This will delete every other node!
  • Paul Munford
    8 June 2010 at 08:57
    beat me to it Al
  • M Brown
    8 June 2010 at 09:02
    Hi All,
    Thank you for your quick and helpful replies.
    I’ll try it straight away.
    From Mark
