Home Forums Vinyl Cutter Discussions Mimaki Cutters Reducing fumes…
  • Reducing fumes…
    Posted by James Culpin on 13 January 2009 at 18:05
    Got a Mimaki full solvent printer and am looking at reducing some fumes and noise that the machine gives out. Currently plan to section off the office so that the printer has it’s own area.
    It’s already vented out an external wall. Has anyone found any other solutions that worked well?
    David Rowland replied 16 years, 12 months ago 7 Members · 7 Replies
  • 7 Replies
  • Owen Lees
    13 January 2009 at 23:20
    We just bunged the JV3 in its own room and vented out the wall like you.
    We find that keeping the media at room temp makes for better prints and so hence the room on its own keeping the media company!
    Oo
  • John Thomson
    13 January 2009 at 23:27
    I don’t find the JV3 noisy….it is the sound of profit!
    as for the fumes all you can do is vent it…..if you can have a separate room all the better.
    john
    13 January 2009 at 23:28
    The only advice I can offer is that I understand the solvents used are heavier than air – therefore, any extraction fans fitted should be at low level to maximise their effect
  • Pauly
    14 January 2009 at 01:23
    Gel filters in the air-con returns works well. Also a carbon filter hooked up directly to the extraction pipes on the machine works well too as long as the lid is closed and the flap at the front has been pulled up!
    As suggested previously, the solvents are heavier than air, but I have found that with some reasonable air flow in the room, some gel filters in the aircon return on the roof will pick it up fine.
  • Benno
    14 January 2009 at 08:57
    If you want to use a filter and keep the frontlid closed I have a tip too:
    Put a piece of foamex between the two feet of the printer on the back.
    This way you create an almost closed space 😀
  • James Culpin
    17 January 2009 at 17:20
    Interesting idea, may just do the job with the screen at front too. certainly worth a try. thanks
    18 January 2009 at 09:24
    its own room with NO Carpet!!
