Home Forums Vinyl Cutter Discussions General Cutter topics Redsail Plotter problem with cutting
  • Redsail Plotter problem with cutting
    Posted by Michal Zabkiewicz on 3 February 2017 at 16:01
    Hi, after 2 weeks I finally sort my problem with connections between PC and Plotter. But now I`ve got problem to cut anything. I tried SingGo Pro and WinPCSIGN Pro 2014 (both trial versions) where WinPCSIGN even detect my plotter. I tried to cut something simple like a circle or HELLO text to test if it work but i doesn`t. What Ive got is a couple of strange shapes and that`s it. I`m using PC with Win7, plotter is connected by USB and RS232 – USB converter.
    Any ideas what might by wrong? Thank you.
    Chris Wilson replied 8 years, 11 months ago 1 Member · 1 Reply
  • 1 Reply
  • Chris Wilson
    3 February 2017 at 21:21
    Don’t have a redsail plotter.
    But had similar problem when we put a 10m extension cable on the USB. Starting cutting very odd shapes. Computer couldn’t find it then it could.Just noticing your word converter there.
    We took the cable off and all fine again. I was told I should of bought a boost with the cable.
    We run signblazer through ours by importing the graphics from Corel draw. It’s a old cheapy one we use for garment film. Was a night mare getting it set up years ago, signblazer found it instantly.
    Don’t know if that’s of any help.
