Home Forums Sign Making Discussions General Sign Topics Recommended thickness of angle iron – Box Signs
  • Recommended thickness of angle iron – Box Signs
    Posted by David Stevenson on 8 October 2024 at 18:47
    Hi, after normally making wooden frames to attach any box signs we’ve fitted, we’ve decided to start using aluminium angle instead which seems a better option. Can anyone advise as to what the recommended thickness of it should be (1/8″, 3/16″, etc)?
    David Stevenson replied 1 year, 2 months ago 5 Members · 6 Replies
    8 October 2024 at 19:10
    Hi David
    I often use:
    2mm aluminium, by 50mm x 50mm Angle
    If the pan is large and in two or more parts:
    2.5mm – 3mm thick Aluminium by 75mm x 75mm Angle
    You will find that when you have a rigid level shelf to slide the pan onto, it gives you a much better fixing, and allows any panel joins to close neatly and flush.
    additionally, I always use spacer bars riveted to create a frame. so the whole thing sits square and is much faster and more secure to fix onto.
    • David Stevenson
      8 October 2024 at 19:19
      Thanks Robert.
      So when you say make a frame, do you mitre the corners and use angle pieces riveted on to join them, or just cut the ends square and rivet them then? Also when you mention spacer bars I take it’s a vertical bar in the centre to keep the frames shape?
      We deal with these guys so going to get some ordered up – https://www.aalco.co.uk/online-tools/product-finder/default.aspx
  • Colin Crabb
    9 October 2024 at 07:52
    we use 3mm for the frames, nice an solid.
  • Jeff
    9 October 2024 at 09:32
    2mm top and bottom. i only do the sides if it is over 3 or 4 feet deep.
  • Mark Johnston
    11 October 2024 at 11:22
    in the past we would use 2×2 wooden batons but now use 2mm angle on the top and bottom full length.
    if the pan is deep i would add two for the side also, but not as a complete frame.
  • David Stevenson
    11 October 2024 at 20:06
    Thanks as always folks for your help. We we’re getting a bit tired working with wooden batons, especially when it was warped and you were trying to join panels together. Going to get some aluminium ordered up and use this going forward. Initially I’d thought about making complete frames no matter the size of the sign but based on the comments here it’s overkill for small signs.
