Home Forums Sign Making Discussions General Sign Topics Recommended Board and Fixings?
  • Recommended Board and Fixings?
    Posted by Joseph Helm on 26 January 2009 at 12:42
    Hi Everyone
    We’ve been asked to quote for a large, full print sign.
    It’s 8’x4′ and it’s going on the side of a building that’s made from stone, so it’s an uneven surface.
    What board and fixings do you recommend for this?
    Joseph
    James Langton replied 16 years, 8 months ago 3 Members · 5 Replies
    26 January 2009 at 12:50
    Dibond or ally tray.
    but you can also get good effect if a flat ally panel is "stood off" from the wall using angle set in from the edge of the panel, so not visible
  • Joseph Helm
    27 January 2009 at 19:13
    Thanks for your reply.
    Do you have any contacts for getting the products you suggested?
    Thanks again
    Joseph
  • James Langton
    27 January 2009 at 22:15
    We did a 21ft x 4ft sign, But the building we did it on had plenty of big dips in it.
    We did it by screwing wooden baton’s to the building using packers to even it out, then screwed the sign trim to it and because it was a front loading system we just popped the panels in and job done.
    If using a sign try its even easier, as the ally angle has got a bit more strength than sign trim.
    James
  • Joseph Helm
    31 January 2009 at 14:52
    What trim and board would you recommend?
  • James Langton
    31 January 2009 at 17:28
    For board i would just use a hording panel.
    Basically whoever you use for your general sign boards should be able to supply you with the suitable kit.
    Its a bit hard for one of the board members to give you a contact number as most suppliers only deliver locally or charge a premium for delivering out of the area.
