Home Forums Vinyl Cutter Discussions General Cutter topics recommendation for Buying a new cutter replacement
  • recommendation for Buying a new cutter replacement
    Posted by JC1520 on 2 October 2014 at 07:56
    All I am buying a new cutter to replace an old jaguar iV i want to have one that is twice as wide as the 24 inch one that we have now.
    This will be used mainly for cutting vinyl within the aviation industry, spray mask, some signs and various other vinyl signs
    I have a Roland printer for printing
    Do i stick with the same family of cutters or what is recommended this will be used daily and does have quite a reasonable output pretty much everyday.
    Nigel Pugh replied 11 years, 1 month ago 4 Members · 5 Replies
  • Cat Wood
    2 October 2014 at 08:34
    If you’re happy with the how your Roland works I would strongly recommend sticking with that series and going for a GX500, this would give you twice the width you’re currently operating. If you’re used to using the Roland software and the way they operate you’re likely to find it very easy to get to grips with. It also comes with the same level of support etc that you’ll expect from Roland.
    What printer are you using?
    Happy to help if I can,
    Cat
  • JC1520
    2 October 2014 at 08:42
    Cat thank you
    I might have worded my thread a bit wrongly
    I have a Roland for printing small BN20.
    I am replacing our cutter which is a GCC Jag IV
    This was here before my time i want it replaced with a good robust but with 4 foot capability.
    I like the GCC but this is now old and i guess a cheap model at the time of purchase.
    I am new to this model it works find but i am starting to cut bigger graphics now as the demand is getting bigger since i have arrive to get this graphics department of the ground.
  • Cat Wood
    2 October 2014 at 10:30
    Ah I see, well the GX would do the same function as the GCC, personally I have no experience of those cutters but our technical engineer suggests that the Roland would be a step-up from that product.
    If you’re looking for something bigger, that’s reliable for more output perhaps the GX would work for you?
    Hope you find the right product 🙂
    2 October 2014 at 11:27
    If you have been happy with the machine you were using & happy to stay with the same brand then speak to Nigel at Grafityp, they sell that brand of plotter.
    Nigel is on the forum quite regularly so will probably see this thread anyway.
  • Nigel Pugh
    6 October 2014 at 11:46
    Would have replied earlier but I took a weeks holiday last week, if you want a Jaguar IV 132S then we have a couple coming into stock in two weeks time.
    Not sure why the Jaguar doesn’t seem robust enough, there are original Jaguars out there still running well past 10 yrs of use.
    Nigel
