Home Forums Sign Making Discussions CNC Router and Engraving Rebating Acrylic Letters
  • Rebating Acrylic Letters
    Posted by Mohsen Hajebrahimi on 12 October 2020 at 13:47
    Hello Dears
    I need to rebate edges of the letters using my Festool 1400 EBQ-plus router
    the material I need to rebate is 5 mm & 3 mm thickness of Acrylic and I need to rebate by 1mm & 2mm deep and 1mm & 2mm into from the edges
    what would be the best router bit to use for that purpose please?
    Also I need a basic router table if you have any recommendation for that as well!
    just to mention that letters are in different shapes as I’m sure you know that (like sharp 90 degrees, 15 degrees 25 degrees and so on)
    I just said that to specify that the router bit needs to be very fine
    I’d appreciate your help and advice
    Mosen
    Mohsen Hajebrahimi replied 5 years, 2 months ago 1 Member · 0 Replies
