Home Forums Software Discussions Corel Software Really Need Help Please
  • Really Need Help Please
    Posted by Nicholas Gormley on 17 July 2009 at 16:42
    Hi All,
    Im having a problem(Sort of big problem), I have Windows Vista Business and have CorelDraw X4 on it. I have a Roland SP-540v and VersaWorks 3.0. When i do a logo or art work in CorelDraw and then put a cut path on it and send it to Versaworks it doesnt come up with the cut path around the artwork and wont cut. Can anyone help me out?? Any help would greatly be appreciated. Has anyone else had this problem and got it fixed??
    Nicholas Gormley replied 16 years, 4 months ago 3 Members · 3 Replies
    17 July 2009 at 17:35
    I’m not sure about versaworks – but I know that with the rip I use on my Cadet (which I think is related to versaworks) you need to check the "Process cut paths" box before you open the file otherwise it won’t see the cut path. (Checking the cut path box after the file is already opened does not work).
  • Kevin Flowers
    17 July 2009 at 18:30
    can you see the marching ants (will only show up when print & cut or cut is selected) when you put the file in VW, have you checked that it is set to Print, Print & cut or cut. If you can not see the red marching ants around the picture then it is not recognizing the cut line if this is the case have you loaded the Roland cut line for Corel.
  • Nicholas Gormley
    18 July 2009 at 07:51
    Hey Everyone problem solved. Done what phil said there thats what cured it. thank you so much for all the help.
