Home Forums Printing Discussions Roland Printers Realistic printing expectations and Media query
  • Realistic printing expectations and Media query
    Posted by Tom Davison on 13 October 2009 at 12:12
    Hi guys,
    Were trying to print out some business card size labels with very fine text on them, even has .eps files they are coming out quite grainy and because the background is black with white text under an eyeglass it looks like it’s mis-registering if such a thing is possible? This is on an Orajet Vinyl. I’m using the specific Orajet profile for this media. I’ve switched to Uni-directional and this gives smoother results but they’re still mis-registering under an eyeglass.
    Also for our general poster work we use BlueBack paper (120gsm) and it’s taking forever and a day to dry on high coverage areas even with all the dryers on and turned up. I’ve been using this machine for a few months now and I’m sure that earlier on the machine performed better than this. We’ve had a couple of engineer visits for various things and the machine recently (>1month ago) had a full service.
    Is this machine "cut-out" excuse the pun, to do small work like this? I want to know whether were fighting something that will never work or whether it’s us/machine at fault!
    I’ve recently attended the Walsall College Roland Academy course but there was very little covering troubleshooting! All files are set to High Quality from the RIP.
    Gert du Preez replied 16 years, 2 months ago 1 Member · 1 Reply
  • 1 Reply
  • Gert du Preez
    13 October 2009 at 15:36
    Tom,
    Start at the beginning. Print a test pattern, and look for any deflection / missing lines in the print. The black is usually the first one to give problems, because (I believe) there is much less ink flow through the head. Counting the empty cartriges in the office, out of 43 empties only 2 are black, the K in the printer is about half full. Our SP540V prints the sort of thing you mention absolutely flawless – the machine is only 7 months old, and the heads still in perfect condition.
    Try doing a manual head clean as well.
    When printing, reduce the head speed to 400mm/sec, and print high quality.
    Try different media ? I get an "economy" 1 year vinyl, (unbranded) which costs about half what Avery MPI 3000 costs, that prints rings around anything else.
    Good luck!
