Home Forums Sign Making Discussions General Sign Topics re using pop up banners
  • re using pop up banners
    Posted by Dan Hardie on 12 October 2005 at 10:27
    i have 2 pop up style banners which were used at a show last year which need to be updated for this years show. unfortunatley, they are not the interchangable ones. does anyone know if you can apply new printed banner material over the top of the existing design. it seems to be possible but would be very tricky, has anyone ever had to do this before, and did you suceed?!
    thanks in advance
    John Cornfield replied 20 years, 2 months ago 4 Members · 5 Replies
  • Russell Huffer
    13 October 2005 at 17:09
    If it is the spring loaded roll up type then the system will not work as the roll will be to thick to roll back in.
    Most of the ones I do are just double sidded, could you not remove and re tape.
  • Stephen Morriss
    13 October 2005 at 18:48
    You can usually remove the old banner and tape a new one in place. You just have to clean the old glue/tape off.
  • John Cornfield
    13 October 2005 at 21:37
    look at the banner cassette on the sides you should see a hole.
    on a bench pull the banner out past its length to expose the leader, use an allan key to lock the roller cut off your old graphic stick some double sided tape on the leader and stick down the new graphic.
    measure old graphic before printing new one include the non visible bleed required that goes into the base.
  • Dan Hardie
    14 October 2005 at 09:01
    thanks for your comments. we put the new banner over the top of the old one. we left it streched out overnight and then let it return back into the mechanism. believe it or not it wasnt too thick at all for the roll but i wouldnt do it like that again as it is hard to apply well but it was good enough for its purpose
    ad
  • John Cornfield
    14 October 2005 at 20:43
