Home Forums Software Discussions General Software Topics RE : software for putting gems on t shirts
  • RE : software for putting gems on t shirts
    Posted by Tracey Vaughan on 13 November 2009 at 17:52
    I have been looking into putting gems on to t shirts etc, i have seen a system on xpres, which is about £100 for software and £260 for starter pack of gems does anyone use this system, or does anyone know of any other systems available?.
    thank you
    Tracey
    Helen Boden replied 16 years ago 8 Members · 13 Replies
  • 13 Replies
  • Frank Horner
    14 November 2009 at 16:08
    The transfer press offer an alternative but I have no idea of prices.
    The Roland software from Xpres used to be £200.
    Frank
  • Andrew Bennett
    14 November 2009 at 18:50
    I thought the Roland R wear software was more than £100 Tracey, can you post a link please?
    I’m being lazy here of course 😀
  • John Thomson
    14 November 2009 at 22:04
    Xpres are doing it at £100 plus vat
    http://www.xpres.co.uk/shoppingcart/aca … m_Tec.html
    john
  • Andrew Bennett
    15 November 2009 at 11:49
    Thanks John. IS it worth £100 do you think?
    15 November 2009 at 13:14
    are the gems s/a then sealed by the heat press ?
    what does the software do other than put dots in the right place ?
    does it then cut a stencil ? if so what material ?
    just thinking
  • Andrew Bennett
    15 November 2009 at 15:44
    I think it turns a picture into a representation of that picture using dots.
    I think the stones then go into the holes and they are then picked up by a sticky carrier which is then heat pressed.
    I have seen a demo using an engraving machine but this software puts it through a cutter onto….vinyl maybe.
  • John Thomson
    15 November 2009 at 16:45
    Xpres have this instructional video.
    http://www.xpres.co.uk/tech_support/how … gemtec.php
  • Tracey Vaughan
    15 November 2009 at 18:05
    hi yes thanks for replies just checking it out as an option at the moment i had been asked by a couple of customers, for this service but wanted to check out the most cost effective route.
  • Neil Speirs
    15 November 2009 at 18:20
    The Transfer Press system can be found here: http://www.thetransferpress.co.uk/acata … ystem.html you need to invest a whopping £1300 😮 into the system unless I’ve read it wrong.
    Grafityp also have a system available but can’t find it online.
    15 November 2009 at 23:27
    with out any gems to prove it but you have every thing to do it as to see if you want to spend on the software.
    been plying with corel v10 on my laptop and not to long to place dots on a word. i think that on the work machine in x3 would be a lot quicker.
    cut the dots with cheap thick vinyl. weed dots, flood and clean off the gems, pick up with heat transfer tape, press.
    if the heat trans tape picks up the vinyl then need to lift the lot stick to bit of paper then lift off the gems.
    not a permanent solution but will get you going to see if you want to spend the extra.
    i am sure that this could be stream lined in corel x3 4 using snap to object or fit to path.
    i await the sound of guns to shoot me down
    :peek:
  • Kevin Flowers
    15 November 2009 at 23:58
    Chris
    there is a way to set it to place dots by converting text to curves & then using the artistic media brush. You do have to set up the media brush with the correct size dots.
    link, last post on the page
    http://www.uksignboards.com/viewtopic.p … s&start=20
    16 November 2009 at 01:17
    thanks Kev.
    just done this and will with a little fiddling create the cut path, but i presume that you need the gems to create the correct size hole. that the gems will fall in to and stay.
    http://coreldraw.com/blogs/fluid/Rhinestones.png
    thanks to Mr Dunn for that.
    so i might buy some for a laugh.
  • Helen Boden
    16 November 2009 at 10:31
    Hi, my first post, sorry not done an intro yet but I had to add this to the debate. Those systems seem to cut a mask and let the rhinestones fall through the holes. Cut out one process, this machines places the rhinestones directly on the carrier…. Crystal Press
    http://www.youtube.com/watch?v=3-kSMUUE10M&feature=related
    http://www.ioline.co.uk
    Simples
    (Sorry OP wanted only software, still interesting though)
