Home Forums Vinyl Cutter Discussions General Cutter topics Rabbit plotter, Art-Cut software, offset adjusts
  • Rabbit plotter, Art-Cut software, offset adjusts
    Posted by Tonete on 22 September 2007 at 00:47
    Hello,
    I have bought a new Chinese plotter, a Rabbit HX-1360, and I don´t know how to adjust the offset value in the software, because this concept is not used on the plotter interface, or in the software.
    In the "Plotter compensation" menu of the setup of the plotter in the Art-Cut software, I can set two things that maybe go in this aspect:
    – Close. By defect not activated, and with the 0.99 value visible but not active.
    – Sharp angle. By defect activated, and with the 0.48 value. (in mm. all)
    Are these offset adjusts?
    I´m Spanish and my English is limited, more in these technical concepts, and possibly the software has erroneous or imprecise translations on it.
    I´m just with the portable at home, have installed the software here, but plotter is not here. Sunday I will go to try to make it cut perfectly or near it, but I prefer don´t to make experiments, and simply set the right values for its standard knife, that it is a Roland.
    ¿Can anybody help me with it please? ¿Have anyone adjusted one or a similar (because Rabbit fabrics to other brands) and got it working fine?
    Best regards.
    adamck replied 17 years, 11 months ago 2 Members · 2 Replies
  • Tonete
    23 September 2007 at 21:11
    Hello again,
    The plotter is cutting perfectly now.
    Thanks anyway.
    Regards.
  • adamck
    24 January 2008 at 13:18
    what settings did you use?
    I have the bridge pro (same thing i think)
    And the same setup as you, my test cuts are not aligning properly.
    Ad.
