Home Forums Sign Making Discussions General Sign Topics Quote help needed – Correx signs
  • Quote help needed – Correx signs
    Posted by Nathan on 4 April 2005 at 09:14
    The customer wants 3 x 2000mm x 400mm correx signs in 3 different colours with white text.
    1 x Red or burgundy
    1 x Blue
    1 X Black
    Does correx come in these colours or would I have to flood coat them?
    What sort of price should I be quoting for these signs including delivery by courier?
    Nathan
    Simon Clayton replied 20 years, 8 months ago 6 Members · 10 Replies
  • 10 Replies
    4 April 2005 at 09:27
    you will need to cut them as a solid panel with the letters weeded out of the panel. that way you dont need to then cut the white text as the boards colour will do that for you once applied.
  • Simon Clayton
    4 April 2005 at 19:35
    Correx comes in those colours… just cut white text and apply.
    Simon
    4 April 2005 at 20:03
    Simon your right correx does come in those colours, but if it was done the way Robert suggested you would get all 3 out of one sheet.
    4 April 2005 at 20:07
    good point martin… there is also the point of uv stability, i would recon it hasnt got much UV stability at all 🙄
    simon i could be wrong mate but do you not have to buy a pack of ten sheets of correx as minimum order?
    4 April 2005 at 20:18
    Robert you can buy a single sheet from europoint if you want, I normally only buy 5 at a time.
  • Nathan
    5 April 2005 at 16:11
    I decided to quote £52 + delivery per board. Is this about right or am I way out.
    Nathan
  • Nathan
    5 April 2005 at 16:18
    Also the price I quoted for 3mm foamex was £67 + delivery per board.
    5 April 2005 at 16:22
    Nathan, if you get the job, the price is fine or to cheap,
    Dont know what others charge. but I aim to get about £80 for an 8×4 5mm
    fluted sheet with one colour, simple graphics. cut into 6 boards
    5 April 2005 at 16:29
    I just upped my 4×8 coro price to $125.
    Coro comes in tons of colors.
    It is the staple of my existance!
    Love…..Jill
  • Simon Clayton
    5 April 2005 at 16:30
    Good point Martin, but the stuff is so cheap its properly cheaper that the vinyl and also less laying time.
    Yep you can get a sheet at a time Rob, but i do the same as Martin and order some spares..
    Simon
