Home › Forums › Software Discussions › Corel Software › quickest way to fade out
Posted by Craig Newton on 18 September 2009 at 07:27hello all, anybody know the quickest way to fade out the edges of a picture on x3? the design im on needs a few photos floating around the place ad they look a bit hideous as a solid border, cheers guys, craig
David Rowland replied 16 years ago 7 Members · 9 Replies -
Best done in PhotoPaint but if it is part of a layout import your image into Draw, click edit bitmap which will launch PP – goto effects – creative – vignette. On closing PP you will prompted to save which will put your editted image back into Draw for more work.
If you want to retain transparency put image into PP -create object from background – use a mask – mask outline – feather, invert the mask and remove background, place back into Draw
Alan D -
hi alan, when in pp i create from background, click mask, mask outlin and then none of the items are availible to click, any ideas?
You have to draw your mask on once the mask tool has been selected.
Alan D -
Sorry!
Misunderstood thread
I thought it was a suggestion of how to slip away unnoticed when its your turn to buy the drinks -
quote John Singh:how to slip away unnoticed when its your turn to buy the drinks
that’s a dave rowland specialty :lol1: :lol1: :lol1:
If you have Photoshop, open your photo, draw a square about 20mm in then select feather – set to approx 40. Inverse your selection then hit delete. Save as a photoshop file and it doesn’t loose any info and should import straight into corel.
Cheers John
quote Nicola McIntosh:quote John Singh:how to slip away unnoticed when its your turn to buy the drinks
at Hilton prices, dont you blame me!
