Home › Forums › Software Discussions › Corel Software › Quickest way of drawing around this shape?
Posted by Nick Minnery on 17 December 2013 at 15:17Hi guys
I’m using Corel x5. Basically, this image is within a rectangle, but I just want it to be the shape of the award, if you know what I mean??
I’ve tried tracing, but it loses quality doing that. I’ve 3 to do.
Thanks!
Nick
Alex Crosbie replied 12 years ago 7 Members · 10 Replies -
Just the outside shape? If so it’s just a circle and rectangle welded together.
Hi Kev, sorry no. I want that image but without the white area, that makes up the rectangle.
Probably not been clear enough there.
Weld the circle and square together and use it as a mask.
Yep I agree with above circle and square welded together and place image inside container using powerclip 😀
Select all, then go "arrange/shaping/boundary" on the menu.
This will create a single line around the outer edges.Regards
George -
quote Kev Mayger:Weld the circle and square together and use it as a mask.
Exactly as i would do it, i’ve just done it but the file is too big to attach, the max file size is 700kb
A mask would be the shape of the circle, and the rectangle below, combined (or
welded) together to make a single shape. This would then be placed on top of your image, and used as a mask, meaning that you would only see what was enclosed within that shape. Anything outside the shape would be masked, and not seen. -
Sorted! Thanks for everyones help.
I used the ‘Bitmap Colour Mask’ tool, used the eyedropper to select ‘white’, and the surround was gone. It also took away some white from the main image (made it transparent) but I just adjusted the tolerance and it was perfect,
The problem with using a basic mask, was that I had to overlap two images, so I couldn’t really do it that way.
Thanks again
Nick
If only I’d seen this earlier! I have the vector version of these for a client of ours.
We put a cut contour around the shape using a mask / powerclip as discussed earlier.
