Home Forums Vinyl Cutter Discussions Roland Cutters Question from newbie
  • Question from newbie
    Posted by Lee.Barnfield on 10 April 2012 at 08:48
    Just got myself a Roland Camm 1 CX24 and it didn’t come with a lead.
    There are a couple of ports on the side, without looking I assume are serial/parallel ports.
    What leads will work with this cutter? Can you get a USB for it?
    Martin Pearson replied 13 years, 8 months ago 4 Members · 8 Replies
  • 8 Replies
  • Frank Droog
    10 April 2012 at 13:15
    Yes Rolands support serial and parallel.
    But if your computer has neither, you can get a usb to serial adapter.
    I use one all the time
    10 April 2012 at 15:39
    Just be aware that not all serial to USB converters are the same so you need to make sure your plotter will work with the type you buy.
    What computer will you be using for the plotter software as it will make a difference which device will work the best.
    Also check the Roland drivers for the plotter will run with your operating system.
  • Lee.Barnfield
    11 April 2012 at 08:46
    Thanks guys, I downloaded the CX24 manual and it says serial RS232C or a Centronics compatible parallel.
    Found a Centronics parallel to USB lead on Amazon for £2
    11 April 2012 at 10:24
    You would be better off using the serial rather than parallel. Parallel will be much slower.
    You also need a converter with an FTDI chipset.
  • Lee.Barnfield
    17 April 2012 at 11:04
    Having some trouble here….
    Bought a USB to Parallel lead, and trying to install a driver. Tells me that it can’t install a USB driver. Do I select USB as the port or something else.
  • David-Foster-
    17 April 2012 at 13:30
    You will have trouble, as Martin said you need a USB to Parallel converter FTDI chipset (a little box) not just the lead. You will select the Virtual Parallel port when you get the converter.
    And to reiterate what Martin also said, Serial is the best way to go. Are you using a laptop with only USB? If you have a full tower PC I would get a PCI Serial card then you can just use a normal cable.
  • Lee.Barnfield
    17 April 2012 at 13:51
    David, thanks for that.
    I bought a USB to parallel lead with the FTDC chipset, and using a laptop with USB only.
    17 April 2012 at 15:03
    You should have got a driver disk with the converter. Should contain 2 drivers, the one you want is the one to set up a virtual serial port.
    If you google FTDI you will find the website which believe explains how to install the drivers & also has drivers for download.
    Once you have set up a virtual serial (com port) you can install the plotter software as normal.
