Home Forums Printing Discussions Roland Printers question about my PC60!
  • question about my PC60!
    Posted by Lorraine Clinch on 2 February 2006 at 13:41
    Hi all!
    can anyone tell me why, when I am printing from Signlab to te PC60 I am unable to access Signlab? I have to wait until printing is finished-rather frustrating to say the least!
    I have had the printer for a while now, but haven’t used it much yet, so haven’t noticed before.
    Also, (another question, I know) why does it always lay down yellow first, regardless of what the end colour is going to be?
    Cheers, Lorraine
    Peter Normington replied 19 years, 9 months ago 5 Members · 5 Replies
  • David Rogers
    2 February 2006 at 14:45
    For the ‘can’t access’ – maybe you’ve got the SIGNLAB spooler off.
    Top menu. CUT / PLOTTING DEFAULTS [setup button] / PORT (click use spooler) – you’ve probably got it on ‘direct to port’. Or is this just for cutting?
    As for the yellow first thing…it just does. From memory as I’ve not used a PC60 in years, it’ll always do yellow first, black last (CMYK print). I think it’s because it’s the lightest colour, but just guessing there.
  • Lorraine Clinch
    2 February 2006 at 15:07
    Thanks David, now altered setting to spool. It’s fine using the CX24 cutter, just the PC60 causing problem, will see how it is next time I use it.
    Re the yellow printing-thanks, at least I know it’s all PC60’s doing this!
    2 February 2006 at 17:56
    You can change the order the colours print. You have a choice of cmyk, kymc, cmy and ymc (the latter two miss out the black – the black being made up by a combination of the other ribbons). I used to often print either cmy or ymc in order to reduce the running cost (25% less) when printing full colour. The print set-up menu should allow you these different options if printing using the windows print manager.
  • Mike Grant
    2 February 2006 at 22:41
    You can swap the YMC to CMY when you do a reverse print on clear ie. if you are doing a picture. As this then lays down the colours in the right order to view from the reverse otherwise you will get a slight colour cast.
    If you can follow that (?) (?)
    2 February 2006 at 23:05
    Andy Warhol made fortunes when he changed the cymk planes around,
    like in his Che Guevara images.
    I just noticed he was from Jills neighborhood.
    http://www.warhol.org/
    This is an interesting bit
    http://www.warhol.org/interactive/silkscreen/main.html
