Home Forums Sign Making Discussions General Sign Topics protruding post sign
  • protruding post sign
    Posted by Nick Williams on 27 March 2009 at 15:59
    i have to make a sign which will be fitted to a 150 mm round post
    the sign will be 5ft tall by 2ft wide and be protruding from the side of the post not covering the post
    i was thinking i would have to make a aliminium frame and rivet dibond to the frame and then strap it to the post with big steel banding/jubilee clips,
    but to make life easier for me i am wondering if you know of anyone who makes something like this already which i could buy ready made
    thank you again
    Graeme Harrold replied 16 years, 9 months ago 3 Members · 4 Replies
  • Tim Painter
    27 March 2009 at 18:23
    Why not buy a lightbox with no opal or gear trays.
    I think you need some width to the panel then to a solid fixing else it will just twist.
    I also think you need something more man for the job than banding.
    Like a larger scaled exhaust pipe clamp that fixes a section solid to the post – then fix the box to it.
    Others may have more ideas, 5′ x 2′ is a fair size surface for the wind to hit.
    also when did posts have sides…… :lol1:
  • Alistair Richards
    27 March 2009 at 20:19
    What about Ashby’s AS range.
  • Graeme Harrold
    27 March 2009 at 22:40
    quote Tim Painter:
    InSIDE and outSIDE :lol1: :lol1: :lol1:
  • Graeme Harrold
    27 March 2009 at 22:46
    Having something protruding out of a single post that size is going to generate quite a bit of torque on the post, and unless fixed with bracing bars in the ground, it may eventually spin the post in the ground.
    The light box idea is not a bad option, as you may be able to use double wall mount brackets to hold it in place.
