Activity Feed Forums Sign Making Discussions General Sign Topics Projecting sign onto wooden fascia
  • Projecting sign onto wooden fascia
    Posted by Dave Hudson on October 26, 2012 at 7:59 pm
    A customer has asked for a projecting sign to be fitted on one side of his new wooden fascist. Now one side of the bracket will definitely screw into the wooden frame behind, but I’m worried the fixings on the other side of the bracket will miss the frame. Any ideas? Thanks
    Colin Bland replied 11 years, 8 months ago 1 Member · 1 Reply
  • 1 Reply
  • Colin Bland
    October 26, 2012 at 9:21 pm
    Hi dave
    Is there a wall or structure behind the panel which maybe you could get a long fixing into through a spacer ?
    Can you remove the timber panel and add some more timber?
    Can you cut an access trap in the face of the panel and add some timber that way.?
    Is there a top and bottom timber run which you could connect into with some timber or a steel pate on the face of the fascia
    Just some ideas
