Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters Procut 700 blade lifting in middle all the time
  • Procut 700 blade lifting in middle all the time
    Posted by SunnyCUT on 21 March 2016 at 15:01
    Whenever I try to cut the blade won’t cut in middle 100mm of width. Regardless of the design etc the blade lifts up (to not cut)
    I have checked all communication settings etc
    It worked fine previously and now is doing this. If I move blade on x axis using settings on cutter that is ok cos blade is in up position already.
    Any ideas on what to do please?
    John Thomson replied 9 years, 8 months ago 2 Members · 2 Replies
    21 March 2016 at 18:13
    if its the same place on every file you cut then guess the main ribbon data cable is faulty having a intermittant contact
  • John Thomson
    22 March 2016 at 08:23
    Do you have a static cable fitted?
    Chinese machines use electro magnetics to raise/lower the blade…….could be a static electricity issue.
    john
