Home Forums Sign Making Discussions Computers – Tablets – Phones Problems with @ icon on my Keyboard, help?
  • Problems with @ icon on my Keyboard, help?
    Posted by Brian Little on 20 February 2009 at 10:32
    hi folks im looking for an alternative to get to this symble "@" on the key board ….i already have to type in alt 156 to get the pond sign ….help ive got web addreses to do 😀 😀
    mod-edit :police3:
    please use descriptive topic titles when posting.
    this topic has now been edited.
    Brian Little replied 16 years, 10 months ago 9 Members · 16 Replies
  • 16 Replies
  • Matthew
    20 February 2009 at 10:35
    not sure if this is what your after but if it’s Windows, you can go to Start – Programs – Accessories – Accessibility and select the "On screen Keyboard"
  • Brian Little
    20 February 2009 at 10:42
    the cutters still on 98 mathew thats not available but i see what you mean on xp
  • Paul S Martin
    20 February 2009 at 10:43
    Good Option
    If your running Visa
    Start – Programs – Accessories – Accessibility and select the – Ease of Access "On-screen Keyboard"
    Paul 🙂
  • Paul S Martin
    20 February 2009 at 10:49
    Brian
    What keyboard settings are you running under Windows 98 for the @ to not be working, is the P.C set to U.K Keyboard !!
    Paul 🙂
  • Brian Little
    20 February 2009 at 11:02
    quote Paul S Martin:
    Brian
    Paul 🙂
    yip everythings set ok …..i should really bin it ..the £ sign i mange to access thru alt 156 on the keyboard but this is the first time ive never been able to access the @ sign
  • Neil Speirs
    20 February 2009 at 11:06
    what do u get at the moment when u press @
  • Paul Humble
    20 February 2009 at 11:12
    If you go to start>all programs>accessories>system tools>character map you can copy the @ sign then just ctrl V it into place. I know it works on XP and Vista, would imagine 98 would be the same or similar.
  • Paul S Martin
    20 February 2009 at 11:17
    Brian
    What might be good is for you to add say the US Keyboard and delete the UK Keyboard, reboot the p.c and then remove the US keyboard and replace again with the UK Keyboard and then reboot again this might just sort thing out for you, make sure all other setting to do with country and keyboard are also set the the UK
    let me know how things go
    Paul 🙂
  • Dan Osterbery
    20 February 2009 at 11:25
    if you are using 98 you can go to start, programs, accessories, system tools character map.
    And then either copy n paste or it will give you asci code to type in.
    hope this helps, and I ve understood what you want
    Dan
  • Ali Osman
    20 February 2009 at 17:06
    sounds like you have the US keyboard layout set as default, you need to use the UK one, the @ maybe on the the upper of the numbers along the top
    i.e shift and 1 or shift and 2 shift and 3 etc until you find it
  • Brian Little
    20 February 2009 at 17:08
    quote Neil Speirs:
    just a colon neil
  • Brian Little
    20 February 2009 at 17:11
    from your cloective advice ive sorted the problem thanyou my friends …enjoy your weekend
    Regards Brian
  • Nigel Hindley
    20 February 2009 at 17:18
    try ctrl 2 Brian or shift 2,
  • Brian Hays
    20 February 2009 at 18:36
    If you get an "@" when you press shift & 2 then as has been pointed out you almost certainly have it set to a U.S. layout.
  • Nigel Hindley
    20 February 2009 at 19:04
    i really should read ALL the posts properly
  • Brian Little
    21 February 2009 at 10:25
    hi folks sorted …..as you say i do indeed have the us version .When i tried to change it it asked for the disk which i have somewhere who cares with your help ive got my icon : 😀 regards Brian
