Problems using laminator to apply app tape
We have been having major problems recently using our laminator to apply application tape to large print and cut graphics. It is something we’ve done plenty of times before with only the odd problem, but now we seem to get creases which run the length of the print, and get worse as the job goes through.
We are using 1524mm Medium tack Conform app tape. We have only ever used 1370mm and had the same problem from time to time, but now it happens all the time.
It can happen on any job, but it’s worst on laminated print and cut stuff. It’s worse when the decals are running at right angles to the rollers, but the same thing will happen even if they are parallel.
We load the app tape using a 1550mm wide strip of Correx and then pull it tight before clamping the top roller down. The tension on the tape is pretty low to avoid stretching it but it makes no difference if we tighten it up.
I did read another thread on the same issue but the original poster didn’t seem to resolve the problem.
Does anyone have experience of this problem, or can offer any solutions?
BTW the laminator is a 1600mm GBC Arctic Titan. It applies laminate fine.
