Home Forums Printing Discussions Sublimation Printing Problems printing mugs
  • Problems printing mugs
    Posted by Phil Green on 24 July 2011 at 09:35
    Just recently bought 2 mug presses done a first run on them fine, went to print another batch and both seem when printed show the elements of the blanket, wondered if anybody else has encountered this and a cure
    Phil
    Andrew Williams replied 14 years, 4 months ago 3 Members · 4 Replies
  • Ian Pople
    24 July 2011 at 09:39
    I sometimes get a faint imprint from the surface of the blanket I just put a sheet of paper between the transfer and the blanket. But don’t understand the elements showing problem can you post a pic.
    Ian
  • Phil Green
    24 July 2011 at 09:44
    Hi Ian,
    I am at home at the moment will try and post a pic on here tomorrow. So your saying put the print onto the mug then another bit of paper on top of that again??
  • Ian Pople
    24 July 2011 at 09:47
    hi,
    Yes but I only do this if I can see the imprint of the blanket on the mug as the blanket is not perfectly smooth.
    or the clamp may be too tight.
    Ian
  • Andrew Williams
    3 August 2011 at 14:29
    quote Phil Green:
    Phil
    Possibly not enough heat but photos would be needed to confirm. Higher/time temp would cure if this was the cause.
